Could you please explain the following:
1)system factor and C-factor and the significance?
2)are both the terminogies same?
KSS
Posted 09 December 2013 - 12:39 AM
KSS
Posted 09 December 2013 - 05:53 AM
Consider this resource to support your query .
Hope this helps
Posted 25 December 2013 - 09:42 AM
Hope this helps
Thanks Brezih.
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
