Lube Oil For Standby Pump
pump
#1 Shahine
Shahine
  • 21 posts
Posted 19 December 2013 - 08:48 AM
Dear All;
Please, there are two amine Pumps, one ( P-101A) is running and One  (P-101B) is in standby mode, and each pump has it's own lube oil cycle (Lube oil System is completely separated).
And functional specification from vendor shown that:
If the pump is in standby mode, the relative auxiliary lube oil system shall be always ready.
Now,
 for the logic of the pump, there is a pressure transmitter PT for  the oil cycle for each pump, this pressure transmitter trip the pump when the pressure of oil cycle become Law Law.
BUT, Shall I make this transmitter PT, trip both pumps, I mean If P-101A is running and P-101B is in standby , and   PT for P-101B (standby one not running) become low low, shall this transmitter trip the running pump P-101A ?
Note that: there is a FAL (flow transmitter) on discharge line of the pump , in case of law flow will trip the running pump and start the standby one automaticaly.
Thanks;
Shahin.
#2 fallah
  • 5,019 posts
Posted 20 December 2013 - 03:23 AM
Shahin,
Uploading a sketch of the system will clarify the situation much better than a lengthy description...
#3 Sharma Varun
Sharma Varun
  • 125 posts
Posted 21 December 2013 - 12:06 AM
Well Shahin as fallah pointed out a sketch will bring more clarity, so you have independant lube oil ckt. for both pumps, which is a common practice, now as per my understanding of the query, you should not trip the running pump based on lube oil PT alarm in stand by pump.
#4 Shahine
Shahine
  • 21 posts
Posted 24 December 2013 - 06:55 AM
Dear All;
Thanks for your reply and here you can find a schematic drawing showing what I mean.
Shahin
