Shell And Tube Heat Exchanger Design Course
he design
#1 Aashiq
Aashiq
  • 4 posts
Posted 24 December 2013 - 03:24 AM
A two Pass tube, baffled spacing single pass shell and tube HE is used to cool down hot methanol. cooling water flows thru tubes at 25C and a flow rate of 30 kg/sec. Methanol enters the shell at 90 C and should leave at 40C with 152kg/ sec. Perform a detailed deign of the exchanger to determine the surface area of this HE for a valid desigh where shell diameter between the range of (0.15, 0.25m) and the pressure drop across the exchanges both sides less than 0.75atm.
Counter Current, Triangular Pitch and Do= 23.2mm BWG= 16
Please HELP ME FIND AN EXCEL FILE THAT COULD DO ME THIS CALCULATION
As I am stuck in the hand calculation until finding the Friction Factor.
  • 6,735 posts
Posted 24 December 2013 - 04:02 AM
Consider this resource to support your study .
All you need is there .
#3 Aashiq
Aashiq
  • 4 posts
Posted 24 December 2013 - 05:00 AM
Thank you Breizh, Really Appreciate it, It helped but is there anyway I could find a spreadsheet that calculates the Pressure drops across the Shell side and the tube side of the HE??
#4 breizh
  • 6,735 posts
Posted 24 December 2013 - 05:32 AM
An other resource but unfortunately no spreadsheet.
To me more important is the method .
Note : A good reference to have on your shelves : Process heat transfer by Kern
Good luck .
