I have a cone roof diesel storage tank fire protection system proposal,.... with only fire hydrants used as means of fire protection system i was wondering :
- since you need to apply cooling water per NFPA on adjacent tanks ... shouldnot it be done through fire monitors instead of hydrants (dont want any sprinklers as its not the preference of client)
- is coverage from two sides neceessary ... i only need 500 gpm application should i use two monitors in opp directions of tank
- in case only hydrant is used .. fire fighters would have to stand there all the time with Hose..... instead of being able to direct a fire monitor and move back
