What is shut in tubing head pressure? please explain me in detail.
Shut In Tubing Head Pressure
Posted 03 January 2014 - 12:51 AM
Posted 03 January 2014 - 03:08 AM
Hi krishnamurthy,
I Think it is quite self-explanatory
Shut-in Tubing Head Pressure, is the pressure of well head tubing when it is shut-in (nothings flow)
or based on encyclopedia2.thefreedictionary.com
The equilibrated reservoir pressure measured when all the gas or oil outflow has been shut off
I Hope it help
Posted 03 January 2014 - 06:13 AM
As Ervin has replied rightly, Shut-in Tubing Head Pressure is the pressure of well head tubing when well is in shut-in condition, i.e there is no flow across the choke.
STHP can be calculated by knowing the reservoir pressure, reservoir depth, fuild compostion and length of the well tubing.
Trust this helps.
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
