Impingement Baffle.
#1 Bodhisatya
Bodhisatya
  • 156 posts
Posted 05 January 2014 - 10:25 AM
Happy New year to all.
In Air separation Units we use Front End Purification Units to remove CO2 ,moisture and Partly hydrocarbons,so that clean dry air can be processed in the Cryogenic Separation.
The Feed air enters at the bottom through an impingement baffle into the Adsorber towers,so that Air properly distributes properly.
Can anyone throw light on how these baffles are designed (Shape and Dimensions) during the basic engineering stage and what are the guiding factors in doing the same.
Bodhisatya.
Edited by Bodhisatya, 05 January 2014 - 10:26 AM.
#2 Bodhisatya
Bodhisatya
  • 156 posts
Posted 06 January 2014 - 09:53 AM
Delegates waiting for some sort of reply...
#3 Bodhisatya
Bodhisatya
  • 156 posts
Posted 18 January 2014 - 02:29 AM
Looking for some one to help me out ???????
#4 PingPong
PingPong
  • 1,474 posts
Posted 18 January 2014 - 07:11 AM
This is too vague.
There are many possible impingement baffle designs depending on the specific application.
Do you have a rough sketch of how the impingement baffle in your case looks like?
#5 Bodhisatya
Bodhisatya
  • 156 posts
Posted 20 January 2014 - 06:09 AM
Attached File  Impingment Baffle.pdf   41.75KB   43 downloads
This is too vague.
Thanks for replying.
Attached is the diagram you were asking for.
Bodhisatya.
#6 PingPong
PingPong
  • 1,474 posts
Posted 20 January 2014 - 09:52 AM
One could argue whether an impingement baffle for a gas inlet below a supported bed of solids is really necessary. For an inlet at the top of a solids bed it is necessary to prevent the gas blowing a crater in the solids bed. As this mol sieve bed is to be regenerated every now and then, whereby the regeneration gas enters through the top nozzle and flow through the bed in opposite direction of the normal air flow, there is an impingement device at the top nozzle, which is retractable with the elbow N2.
Here they found it necessary to also have an impingement plate at the bottom inlet, although there would be a distance of some 900 mm between nozzle and bottom of bed if the baffle were not there.
So be it, and now you think there is a lot of science behind this.....
In this case it seems to me that the diameter of the circular impingement baffle (750 mm) at the bottom is simply half the diameter of the vessel (1520 mm).
The 432 mm distance between inlet nozzle and impingement baffle is probably chosen such that the gas velocity through this distance is about the same as the gas velocity in the space around the impingement baffle.
#7 Bodhisatya
Bodhisatya
  • 156 posts
Posted 20 January 2014 - 11:24 PM
Sir ,can you please elaborate the above statement. Couldn't grasp you properly.
Bodhisatya.
