I am looking for a calculation method to determine the tube wall temperature in a S&T exchanger. I have found one on a web site, but it merely presents a formula. There is no documentation or basis or indication of acceptance. Can anyone help, please?
Tube Wall Temperature Prediction
Started by Mole Chaser, Mar 19 2006 11:26 AM
Posted 19 March 2006 - 11:26 AM
Posted 19 March 2006 - 11:47 AM
Hi AlanCannon
There is a discussion of about 1 page in the book "Process Heat Transfer By Kern" page 97-98 on the determination of Pipe Wall Temperature. You can go through this and I am sure it will help you.
Hope it helps.
Ali
Hope it helps.
Ali
Posted 21 March 2006 - 04:51 PM
Thanks, Ali. That is exactly what I was looking for. This thread is solved!
Alan
Alan
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Rotated Triangular Tube Layout Vs Triangular Tube LayoutStarted by Guest_Heat Transfer Novice_* , 28 Sep 2024 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
