Good day all.
Is it possible to have an undersized restriction orifice and how do i know this.
I am carrying out a check of an existing blowdown system which has restriction orifices downstream the blowdown valves. The restricition orifices are sized for a max flow of about 5% of the maximum to be expected through the blowdown valve. Now i understand that the function of the RO is to restrict the gas flow so that the flare doesnt become over loaded, but when is the restriction too much such that we are not able to safely depressurize the facility within the required time frame. Hope this is clear.
Thanks in advance
Sola
