Vacuum Column Simulation By Pro/ii
vacuum
7 replies to this topic
#1 mbsahg
mbsahg
  • 30 posts
Posted 12 January 2014 - 07:40 PM
Hello~
Firstly, I can't speak English well.^^
I am simulated about 'Vacuum column'
The simulation condition is under,
1) Feed: AR(Atmospheric residue)
2) Product
 a) Off-gas
 B) LVGO(Light vacuum gas oil)
 c) HVGO(Heavy vacuum gas oil)
 d) VR(Vacuum risidue)
I don't know properties about LVGO & HVGO.(in order to simulate)
I want to know general properties(like to TBP range) in order to simulate.
And I am simulated 'Vacuum column" shortcut model.
Please help me.
Thank you for read message.
Edited by mbsahg, 12 January 2014 - 07:41 PM.
#2 PingPong
PingPong
  • 1,469 posts
Posted 14 January 2014 - 10:34 AM
You first need to define the AR feed and cut it in many pseudofractions.
The LVGO and HVGO products are whatever you want (or need) to produce: what are both these streams going to be used for in downstream units?
What is the purpose of your simulation: just for education, or for actual operating unit?
#3 mbsahg
mbsahg
  • 30 posts
Posted 14 January 2014 - 08:33 PM
Dear PingPong
Thank you for your reply.
I'm had TBP data of AR. and the purpose of process is VR that is to use in 'Asphalt plant'.
Also, i want good yield of LVGO & HVGO.
I am tried to make 'Shortcut model' by PRO/II.
But i'm failed  to realize the shortcut.
#4 PingPong
PingPong
  • 1,469 posts
Posted 15 January 2014 - 02:25 PM
Forget the shortcut.
In the 30 years that I do simulations I have never used any shortcut methods for any columns. For a vacuum column with sidedraws I cannot even imagine that it would produce any useful data. Wast of time and energy in my opinion.
You have the TBP of the AR feed, so that is fine.
As a first trial use a TBP cutpoint of 565 oC (1050 oF) between HVGO and VR.
If the LVGO and HVGO will be mixed and sent to the same destination then the TBP cutpoint between them is not important but should be optimised in view of the two PumpAround duties and their use in a heat integration, or steam generation, or whatever.
As a first trial use a TBP cutpoint of 455 oC (850 oF) between LVGO and HVGO.
Use 2 theoretical stages for the LVGO PA section
Use also 2 theoretical stages for the HVGO PA section
Use 3 or 4 theoretical stages for the wash section between HVGO and column feed
Use 2 theoretical stages for the stripping section
Once you have a converged solution you can vary stages, TBP cutpoints, whatever, to optimise.
#5 mbsahg
mbsahg
  • 30 posts
Posted 18 January 2014 - 03:20 AM
Thank you ~^^
I am trying 'Vacuum distillation' simulation from your comment.
After i am simulation, I am want your help.^^
#6 mbsahg
mbsahg
  • 30 posts
Posted 21 January 2014 - 07:44 PM
I am trying to simulation for vacuum column.
But i am not solving it.
I think that i am entered wrong input data(specification & variable) in simulator.
I want to attach simulation file(PRO/II) because I have your help.
But i don't know how to attach file.
#7 PingPong
PingPong
  • 1,469 posts
Posted 23 January 2014 - 05:12 AM
When you are logged in you will see under the Reply window a grey button [More Reply Options].
Press that button and under in the new screen you can upload files.
#8 krazykutie
krazykutie
Posted 23 January 2014 - 10:12 PM
test
