Hello everyone.
I need some help in modelling a fluid tank into Laplace domain. The system looks like this:
http://blog.opticont...ol1-300x161.png
but the difference is that I don't have a pump at the bottom of the tank (the liquid flows directly by means of gravity and pressure). Also, the input feed can be considered constant. Thus the level in the tank is controlled by the control valve at the outlet of the tank.
I've tried searching some materials concerning this topic, but I can't find any material that discusses the height of the tank (output) in regards to the opening of the control valve (or the outflow rate as input). Is there anyone who is able to help? Thank you ![]()
