Purge gas is being injected into high pressure gas line prior to start up. During operations, there are 2 ball valves and 2 check valves that prevent the backflow of the high pressure gas into the purge line. However, there is also a PSV for extra safety on the purge gas line. I am wondering what what is basis to determine the relief rate.......initially I thought you would have to size the psv for entire load of the high pressure gas line..but I am told that this is incorrect....Please advise.
Thanks.
