Dear all,
I’m studying a surge analysis for liquid filled systems in a project at its preliminary stages.
The scenario I’m studying is the failure close of an on-off.
I´m in the preliminary stages and then I do not have yet vendor information.
Under my preliminary result I have had the next observations:
-In general terms, the full open CV of an on-off valve is very high to modify the flowrate through line. It only starts to affect the flowrate once a minimum value is achieved.
As an example: if the CV of an On-off valve 2500 , it will only start to change the hydraulics of the system if a CV lower than 500 is obtained due to the closure of the valve.
-Due to this fact the travel vs Cv can highly affect the results (see attachement).
example.pdf 94.51KB
55 downloads
If we consider a linear closure from 100% open to completely close in 10 seconds, a linear valve will change the flow from 100% flow to zero in 2 seconds, whereas an equal percentage will change the flow from 100% flow to zero in 4 seconds.
A linear valve will provide a higher pressure for surge calculations.
Then I would like to know if it is typical that on-off valves are designed to be equal percentage or if they are designed to be linear. Additionally, I’d like to know if the degrees of travel vs time is typically linear or equal-percentage.
At the end my objective is to know how the CV changes with time.
I have tried to contact vendors in different projects, may be the service in spain is not good, but they don’t usally answer this kind of questions. They usually have information about control valves, nevertheless they do not have it for On-Off valves.
Then I’d like to know if somebody In the forum could advise me regarding how the of On-off valve reacts with time during its closure
Kind regards
Edited by Mark-TR, 30 January 2014 - 07:08 AM.
