Psv Downstream Piping Material
psv downstream piping
#1 Tween
Tween
  • 41 posts
Posted 07 February 2014 - 12:09 AM
Is it mandatory to make "low temperature carbon steel" at the downstream of PSV ? or Can we ignore the"LTCS" if the releiving temperature is normal in simulation model?
Please suggest..
Thank you
#2 fallah
  • 5,019 posts
Posted 07 February 2014 - 01:58 AM
teesan,
If PSV discharge temperature would be lower than -29 C and higher than -46 C, you should use LTCS as PSV tail pipe material...
#3 Tween
Tween
  • 41 posts
Posted 07 February 2014 - 02:05 AM
Thank you fallah
