I work at a 300mmscfd (2-150mmscfd trains) Amine treater in South, Tx. We are treating H2S and CO2 with 315 GPM of MDEA (Jefftreat MS100). I have about 13 months of experience. Our overall training process is kind of "learn as you go" so I've been aquiring textbooks, articles, and surfing this forum for a while trying to better understand the process. I've been able to research most of my questions but seem to be stumped on this one. A rule of thumb out here is we should keep our "Reflux Temp" (Temperature coming out of our reflux condenser, going into our Reflux accumulator) 10 degrees warmer than our Gas cooler temperature (Gas stream coming out of our Gas Coolers). No one has an explantation why other than "because I said", and I have been unable to find anything online. Per some of my research the only purpose of pumping the reflux back into the top of the regenerator is to cool the top of the regenerator. However, I've read on here that there really isn't an advantage to pumping the reflux back into the regenerator at all that its actually better to use it in other areas of the process. So i'm looking for some insight on ideal Reflux Temperature and why.
Simple flow diagram of our process:
Gas-
Inlet Filter Sep--->Amine Contactor--->Gas Cooler--->Amine After-scrubber--->Glycol Contactor--->Glycol After Scrubber--->Residue Sales
Amine-
Lean Amine Surge--->Amine HP's (315gpm at 1200 psi)--->Amine contactor--->Rich Amine Flash Tank--->Rich Amine Pre-filter--->Carbon Filter --->Rich Amine After-filter--->Exchanger--->Top of Regenerator--->Regenerator Bottoms/Reboiler (Thermosiphon tube and shell with Hot Oil System)--->Exchanger--->Amine Booster Pumps--->Amine Cooler--->Lean Amine Surge Tank.
We refer to the reflux as the steam generated by the reboiler as it leaves the top of the regenerator, then is condensed through the Reflux Condenser/Cooler and dumps into the Reflux Accum. then is pumped back into the Rich Amine feed going into the top of the regenerator.
Hopefully I covered everything. Thank you for any input. Feel free to ask anymore questions you have. Thank you.
