your diagram has 325 trays, but at my T&P (40c, 16 Bar) my rough design gets only to 120? which should only be a single column?
Those 325 trays were
actual trays, not theoretical, to produce polymer grade propylene.
Theoretical trays were 214 in this particular case, including the pasteurization section, so about 196 for C3 splitting.
How many theoretical stages you need depends on your feed composition and your propylene specification. How many actual trays that are depends on the type of trays you use. Whether that number will fit in one column depends on the diameter of the column, or better: on the L/D ratio.
i have 50 mol% h2, to separate out of the feed.
If the feed to the column contains as much as 50 mol% H2 you should probably remove that in a separate higher pressure column upstream the C3 splitter, otherwise you will lose a lot of propylene with the vent gas. In any case you should include a
vent condensor (cooled by a refrigerant) like in the drawing.
