Cryogenic Air Separation Simulation By Hysys
Posted 26 February 2014 - 04:05 AM
Posted 26 February 2014 - 04:08 AM
i am also attaching simulation file and PFD second (continuation) drawing
Posted 26 February 2014 - 04:12 AM
Here i try to attach my working HYSYS file and i failed. if any body wants i can mail to your mail ID
Looking for a postive and handy replys
Posted 26 February 2014 - 10:17 AM
Please zip the file and attach it.
Also prepare a good single page pfd and attach it..The given diagram is too untidy.
What I get from the diagram is it's an N2O2 plant without Argon .Is it so ?
Why do you need Shortcut Columns,a refluxed absorber and a reboiled absorber will serve as HP Column and LP column respectively.
The statement that Linking of streams from Column in MHE is not happening is quite,why can't you link those streams.Are you getting Temperature cross?.
Also please quantify the model.Air Flow and Pressure,Booster Air Compressor Pressure,Turbine configurations and finally Product specs.
Bodhisatya.
Posted 03 March 2014 - 10:49 AM
Shortcut columns will not be adequate for this model. you need to use a full distillation block.
Posted 08 March 2014 - 01:01 AM
Thanks for reply Bodhisatya,
I attached SCADA screens contains the PFD running Conditions for your reference,
Looking for your positive & handy reply,
Chowdary
Posted 08 March 2014 - 01:29 AM
Dear Friends.
I attached my hysys file. I am going with Rebiled absorber as the LP column and refluxed absorber as the MP column.
Please go through the attachement and help me in convergence of the process.
Lokking for reply,
Chowdary
Posted 08 March 2014 - 01:31 AM
Thanks for reply, I attached SCADA screens for PFD and Hysys file for the simulation. Please help in convergence of PFD in simulation
Posted 08 March 2014 - 08:09 AM
Tummalap:
Unfortunately the build of the Hysys you are using is higher than the one I use ,so can't access the same.It would be great if you convert the ffile in.xml format,i.e please sace as hysys case files in .xml format.
Sorry for the inconvenience caused.
Looking forward to help you.
Bodhisatya.
#10
Posted 02 April 2014 - 09:06 AM
Dear BodhiSatya
here i attached hysys Xml format file. pls go through it and help me in convergence
#11
Posted 03 April 2014 - 12:44 AM
I don't find any attachment.
Bodhisatya.
#12
Posted 03 April 2014 - 08:06 AM
BodhiSatya:
Here is the document.
Posted 03 May 2014 - 02:06 AM
Sorry for the delay caused, I was tied up at the work front. I have simulated the plant as per your spec,please review the same at your end and let me know if it serves the purpose. There is a slight mismatch in the duties of the Reboiler and Condenser; I am trying to find out the reason behind this.
Again sorry for the delay.
Bodhisatya.
#14
Posted 03 May 2014 - 02:10 AM
Attaching the file with this post.
Bodhisatya.
Posted 09 May 2014 - 06:04 PM
#16
Posted 10 May 2014 - 02:33 AM
Not sure about the Splitter operation,but if your aim is Quick simulation why don't you try the shortcut Column.
Bodhisatya.
#17
Posted 11 May 2014 - 02:07 AM
dear bodhisatya,
Thanks for nice work. but The simulation file is not orderly simulated and linking is missing,
can u pls once go through it,
Thanks & Regards
T.P.Chowdary
#18
Posted 11 May 2014 - 07:39 AM
Can you please elaborate the hurdles.Which Linking are you referring to ?
Bodhisatya.
#19
Posted 21 May 2014 - 03:53 PM
Hello Dear
I think this simulation maybe useful for this project.
Posted 28 May 2014 - 12:50 PM
Hello javaheri,
I've went through your file and couldn't figure out how to converge it.
Can you please reattach the converged one?
I first try to solve the problem by converging the post process of first file presented by chowdary and still giving me consistency error.
many thanks
Shin
#21
Posted 28 May 2014 - 02:51 PM
Hello S.YOO
I Compeleted the Chowdary simulation too and put it on the Previous Post. this attached file in the converged one.
Please after open file, run the Distillation column. this error occur because type file most change to XML for uplod to this post.
Posted 29 May 2014 - 01:48 AM
I have gone through your file (although superficially), and I find there is wide spread difference in the reboiler and condenser duties. Being an integrated reboiler-condenser configuration, we need to match those values for an Air separation unit to work. The file I attached too had a certain mismatch but not to the extend your file shows (The reason being the plant we are simulating is a partial part of an Argon separation unit). Need to compare both the files.Please check at your end too. At current state, this simulation will not work.
Bodhisatya.
#23
Posted 30 May 2014 - 07:35 AM
Hello Bodhisatya
I check this simulation and I try to solve this mismatched.
Thank you for your attention.
javaheri.
#24
Posted 09 June 2014 - 12:04 AM
Dear Chowdary,
I went through the SCADA you have posted and would tell me which SCADA is this from? I just like to know the detail or background of this SCADA. and where this plant is and what is this ASU is for? For example, Is this ASU is for some gasification needed process?
best regards
Shin Yoo.
#25
Posted 09 June 2014 - 02:17 AM
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
