Hi all,
I have slight delima. I am trying to size a control valve for water but am uncertain on the pressure drop I should use. The water is at 70 F, 40 PSI inlet, 10-40 gal/hour through 1/2" tubing. About 20 feet after the valve air will be injected at 100 PSI and about 10 inches later the water/air will be released to atmosphere by means of a misting spray bar. Please see the attached PFD.
If I assume a 40 PSI drop, my Cv is about 0.026, which is very small so I don't think this is correct.
If a typical 10 PSI drop (1/4 the inlet), I get a Cv of 0.053, which seems a bit more realistic. My formula is Cv=Flow (GPM) * Sqrt(S.G./dP (PSI))
1. Which dP should I use for the sizing?
2. Does the air injection complicate this at all or should I ignore it?
Thanks in advance!
