Dear,
Experts, I have a little problem. How to set up a design spec in Aspen hysys? For columns it is quite easy. I am trying to set a Component flow of an outlet stream (from a reactor) by changing the flow of one of the inlet streams . This option is readily available in Aspen plus which I have been using. Kindly advise.
Thank you
