Darshan:
I presume this topic is related to another topic you raise in http://www.cheresources.com/invision/topic/20383-practical-ways-to-increase-the-reciprocating-compressor-cng-efficiency/
If it is, then we are discussing CNG compressors that are designed to operate intermittently, with 3 or 4 stages of compression and running at a relatively high rpm (usually directly coupled to an induction motor or a gas engine). I do not believe it would be cost effective to contemplate converting an induction motor to a Variable Frequency Drive (VFD) on these type of small machines (approx. 150 kW). As we say in Texas, the cost of the laundering would be more expensive than the shirt.
If you increase the rated speed of a reciprocating compressor, you increase the rated capacity of the machine – but you also increase:
- The demanded horsepower load for the machine;
- The interstage pressures;
- The interstage cooling requirements;
- The operating action (and wear) of all the compressor valves;
- The wear and tear of the piston rings;
- The oil lubrication for the bearings as well as the cylinders (assuming they are oil lubed);
- The piston rod loads on each of the individual stages;
- The wear and tear on all bearings, crosshead, and piston rod packings;
- The vibration and pulsation effects on the overall machine;
- The pressure drop between stages.
There may be other effects that creep in, but the above are the major ones I would be most concerned about – especially the rod loads. I definitely would not go forth with this concept or idea of increasing your CNG capacity by simply changing to a faster (and higher Hp) driver. In my experienced opinion your CNG compressors are not designed as heavy-duty, robust process machines. You are limited to the nameplate capacity and operating conditions you bought them for.
