Hi there,
I am on the track of designing a heat exchanger for my project.
I was wondering where i can get the recommended standard tube lengths. I know TEMA has it but the library does not have a copy of the standards book.
Any ideas where i can find this?
Cheers!
Standard Tube Lengths?
Started by Dinosaur, Mar 28 2006 04:18 PM
Posted 28 March 2006 - 04:18 PM
Posted 29 March 2006 - 09:28 AM
Hi
You can find the Standard Tube lengths for Heat Exchangers in "Process Heat Tranfer" by Kern. I have seen the lengths given in this book. The length is usually 16ft, 20ft (shorter length can also be used, it is given in the book). You can also get this information from any other Heat Exchanger design book.
Hope it helps.
Ali
Hope it helps.
Ali
Posted 29 March 2006 - 09:41 AM
hi thre !
I completed my project on designing n optimisation of heat exchanger(shell n tube). And i found diff sets of tube lengths used both by Kern n Ludwig ( 8 ft and 20 ft) . So goin after my prof's advice i consulted the corresp heat exchanger standards (IS 4503, here in India ) So u can go for the standards available thre in UK or international stds.
Hope it'll help !!
Hope it'll help !!
Posted 29 March 2006 - 11:42 AM
Hey thanks man!
I have however, located the TEMA book! and photocopied the relevant tables...
![]() Rotated Triangular Tube Layout Vs Triangular Tube LayoutStarted by Guest_Heat Transfer Novice_* , 28 Sep 2024 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
![]() Tube Rupture ReliefStarted by Guest_felderosfelder101021_* , 16 Jan 2025 |
Applicable Standard For Ethane Import And Regasification TerminalStarted by Guest_bisen1986_* , 19 Nov 2024 |
Maximum Mass Flow In A Shell & Tube Heat ExchangerStarted by Guest_DonStalke_* , 22 Sep 2024 |
