How To Calculate Heat Reaction - Hysys
#1 lipchakster
lipchakster
  • 7 posts
Posted 25 March 2014 - 08:43 AM
Hi, i need to calculate the heat of combustion in a C-Reactor.
Edited by lipchakster, 25 March 2014 - 08:48 AM.
#2 lipchakster
lipchakster
  • 7 posts
Posted 25 March 2014 - 08:47 AM
I want to reformulate the question. What I need is the heat of combustion.
#3 PingPong
PingPong
  • 1,469 posts
Posted 26 March 2014 - 03:50 AM
Heat of combustion can be calculated from the heat of formation (enthalpy of formation) of reactants and combustion products.
#4 Said Salim
Said Salim
  • 98 posts
Posted 27 March 2014 - 05:52 AM
Hi lipchakster.
PingPong is Right you can use Hess' Law using the standard heat of formation values for the products and the reactants
this link can illustrate this method.
http://www.chemteam....sLawIntro2.html
#5 Bobby Strain
Posted 27 March 2014 - 06:33 PM
Hysys has among its properties heat of combustion for a stream. You shoulds have access to component values in the library, too. And there are available lots of references for same. Mostly the values are given at standard conditions. Did you search with Google?
#6 lipchakster
lipchakster
  • 7 posts
Posted 31 March 2014 - 07:58 AM
Thanks, I ve already calculated the heat of combustion using the enthalpies variation.
Thanks again.
