Good day,
I would like to ask all of you for some suggestions regarding my concern. I am planning to include Hysis in my MS thesis topic. Any ideas how I can incorporate the software in my studies. Many thanks.
Posted 27 March 2014 - 08:14 PM
Good day,
Posted 28 March 2014 - 11:14 AM
I read this work online where someone used Hysys with his Master's thesis. Attached.
Posted 28 March 2014 - 02:20 PM
Hysys is just a calculator that can be used for a thousand and one different problems.
You best make a list with subjects that you are really interested in, and then find out which of those can use Hysys.
There are many documents on the internet about working with Hysys. See also film clips on youtube.
Posted 31 March 2014 - 10:26 AM
To determine if you will/or can use HYSYS your thesis should be defined first and then you can use HYSYS for if's.
Posted 27 October 2014 - 12:15 AM
Thank you very much for all the inputs
![]() Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Hysis Vba Mixed Liquid Phase Data AccessStarted by Guest_Jose123123_* , 27 Dec 2022 |
Suggestion To Choose My Thesis: Desalination Or Nanofiltration?Started by Guest_ChemJack_* , 29 Sep 2017 |
Undergraduate Research/thesisStarted by Guest_ericksayloon_* , 12 Aug 2017 |
![]() Required Relieving Load In Hysis For Control Valve FailureStarted by Guest_nivedita12_* , 25 May 2016 |
