Hi all,
How do you calculate or obtain the steam saturation temperature upon designing a vertical thermosyphon for a column? thx!
Posted 30 March 2014 - 08:28 AM
Hi all,
Posted 31 March 2014 - 02:15 PM
If you want to calculate a steam temperature, you need to know the heat transfer area of the thermosyphon.
Then calculate the required LMTD from LMTD = Q/UA. Then doing a little trial and error, calculate the steam temperature. Be sure the LMTD isn't so high that the maximum allowable heat flux is exceeded.
Posted 01 April 2014 - 07:04 AM
thanks srfish!
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
![]() Steam Used In ReboilersStarted by Guest_aliebrahem17_* , 05 Jul 2025 |
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
