Now i am doing a assignment , i need to know about the different between distillation and absorption packed column , which website can get this kind of information?
Can Anyone Tell Me The Different Between Distillation And Absorption P
Started by Guest_Mr. Ooi_*, Mar 29 2006 03:39 AM
Guest_Mr. Ooi_*
Posted 29 March 2006 - 03:39 AM
Posted 29 March 2006 - 08:45 AM
i think u should hv a search in google. If u want an accuracy answer if not may be i can help u.
Posted 29 March 2006 - 09:57 AM
Hi
As long as my understanding, the Packed Column used for Distillation and Absorption have the same function i.e. to provide intimate contact between two phases so that the mass transfer is enhanced and for this packings are used.
The only difference is in the process, Distillation uses difference in Boiling point to Removal more volatile component from less volatile component by contacting Liquid and Vapor Phase. While in Absorption we ue the difference in solubility OF Liquids in the gas for separation.
Hope this Helps.
Ali
Hope this Helps.
Ali
