I'm calculating PSVs for a Shell and tube heat exchanger. Fire case is the sizing case for PSVs on both sides. Shell side saturation temperature is higher than the one on the tube side for the relieving conditions. Then, I estimate the amount of heat that could be absorbed by the tubes, and it's bigger than the heat received by the shell from the fire. So, it seems I should transfer the entire heat from shell to tubes.
So to calculate relieving rates I'm doing:
Tubes: (Qhead+Qshell)/Heat of vaporization(tubes fluid).
Shell: Qshell/Heat of vaporization(shell fluid) I'm not taking credit for the heat absorbed by the tubes.
Do you think this approach is acceptable? Is it too conservative?
Thanks in advance for the help.
