Freezing Point Vs Vacuum Pressure
#1 sateeshkumar830
sateeshkumar830
  • 40 posts
Posted 03 April 2014 - 09:38 AM
Hiiiiiii
        What is the relationship between freezing point vs vacuum pressure. I have done MDC distillitaion under vacuum. -20c utility was used for condenser. Mdc(Methylene dichloride) Freezing point is -40c. But condenser got freeze. i know the relationship between boiling point vs vapor pressure.  We will calculate this by using antonie equation. But what is the relationship between freezing point vs vacuum pressure. on what parameters it does depends. We have to use same formula or what.
Hope expecting replies from you.
                                                       Thanking you.
#2 PaoloPemi
PaoloPemi
  • 550 posts
Posted 03 April 2014 - 10:31 AM
for estimating freezing point of a mixture you can solve phase equilibria,
a simple solution would be to use the relation for solid's vapor pressure,
I attach as example the temperature dependent parameters
in Prode Properties data bank for methylchloride,
possibly you have other components since my values (for pure methyl chloride and dichloride) are lower
than yours (about 178 K as freezing point for pure dichloromethane or methyl dichloride)
for mixtures a better approach would be a method such as
Prode Simplified Solid Solution Model (SSM) for multiphase equilibria,
SSM calculates fugacity of solid phase from fugacity of liquid phase,
this allows to solve both vapor-solid and liquid-solid equilibria
as well as multiphase
Edited by PaoloPemi, 03 April 2014 - 11:22 AM.
#3 sateeshkumar830
sateeshkumar830
  • 40 posts
Posted 17 April 2014 - 12:34 AM
Waiting For More Replies.. Please anybody Respond to my question.
#4 marchem
marchem
  • 153 posts
Posted 17 April 2014 - 01:50 AM
which answer do you wish to receive ?
Have you read Paolo's post with the notes about methyl dichloride freezing point ?
You may give us more detailed information.
