Should the relief valve materials and tailpipe materials e selected based on worst case low temperatures.
I have a relief valve for a fire case relief. Outlet temperatures during relief are between 30-45 degrees C.
However if my system was blocked in at CITHP and minimum operating temperatures and my relief valve leaked I could get very low temperatures down to -90 degrees C.
Should I select my tailpipe / RV materials based on this potential low temperature due to leakage? Or just base outlet temperatures on the relief case? Its the difference between a carbon steel valve / tailpipe and a stainless steel valve / tailpipe.
