Please find the attached sketch for the relief valve [RV01] & bursting disc [BD01] on a reactor discharging to a dump tank. (nozzles N1 & N2)
All the elbows are long radius [R/D = 1.5] elbows. Please find other info on the attached file.
- RV01 inlet pressure drop is 0.17bar which exceeds [significantly high!] 3% of set pressure [0.06bar] at the rated capacity [8000kg/hr]. What could be done?
- What maximum inlet and outlet pressure drop should I allow for bursting disc?
PS: RV01 outlet pressure drop is OK [within 10% limit]
Edited by kinetic123, 07 May 2014 - 10:40 AM.
