Hysys Excel Vba Link
11 replies to this topic
#1 Vijay_G_K
Vijay_G_K
  • 6 posts
Posted 13 May 2014 - 09:25 AM
I am trying to extract the content of notes tab of each stream of hysys.
I able to fetch other values of the stream through vba excel but not getting the way to fetch the Notes Tab content.
Below is a part of my code.
Please help on this.
Thank in advance.
    Set hyOperations = hyFlowsheet.Operations
    Set hyStreams = hyFlowsheet.Streams
    For Each hyStream In hyStreams
'I want the code to extract content of notes tab for each stream here.
    Next hyStream
End Sub
#2 Bobby Strain
Posted 13 May 2014 - 09:44 AM
Try Aspen Tech support site.
#3 pavanayi
pavanayi
  • 258 posts
Posted 13 May 2014 - 10:25 AM
Just checked the Hysys object browser. I couldn't find anything related, so I think it is either not available, or not exposed.
#4 Bobby Strain
Posted 13 May 2014 - 01:56 PM
So, you still haven't done as I suggested.
#5 Vijay_G_K
Vijay_G_K
  • 6 posts
Posted 13 May 2014 - 11:55 PM
Thanks Bobby,
just today I created my username in aspen tech support site.
May be I will receive the mail in 2 days as pr there info on site.
#6 Vijay_G_K
Vijay_G_K
  • 6 posts
Posted 14 May 2014 - 06:16 AM
If it is not in the object browser then how it can be displayed on hysys window. is there any other way to find this "Notes" tab.
Actually while modeling we go on writing the comments in this note tab only, and it becomes very much difficult to summarize all the notes from all the streams or operation object.
If it can be done using excel vba it will help me a lot.
thanks.
#7 Bobby Strain
Posted 14 May 2014 - 09:18 AM
Download HSR from the site and you can find the code in there to do what you want. Notes are not exposed in the object model, so you have to use the backdoor approach to retrieve the note. Good luck.
#8 Vijay_G_K
Vijay_G_K
  • 6 posts
Posted 15 May 2014 - 12:06 AM
Thanks Bobby for the suggestion.
I have the HSR. Actually I learned the Excel hysys link by HSR. But in that no code is related to the "Notes" tab.
Backdoor approach I am not aware of. Can u post an example if it is readily available with you.
Vijay
#9 Bobby Strain
Posted 15 May 2014 - 09:20 AM
You should search all the code with the search feature. Search for whole word Notes. Seek and you shall find.
#10 Vijay_G_K
Vijay_G_K
  • 6 posts
Posted 21 May 2014 - 08:06 AM
Thanks bobby,
I got the solution in hsr. although it is verry much tricky but my purpose is solved.
Vijay
#11 pavanayi
pavanayi
  • 258 posts
Posted 21 May 2014 - 09:07 AM
Please note, that back door approach may stop working when a new version is released. (Even though, the methods  I have used have not changed between versions till now, that does not mean it won't in the next release)
#12 Vijay_G_K
Vijay_G_K
  • 6 posts
Posted 22 May 2014 - 02:23 AM
OK.
Although We are using 6.5 which is much latest. and if that script dont work atleast i know the steps how it works.
but i will take care of version change.
Vijay
