Hi all,
I have a question regarding minimum gas velocity effect in piping. Currently we are in design phase of an amine plant (80 sgpm). Client have provided following conditions for design.
Gas Maximum Flow: 30 MMscfd
Gas Minimum Flow: 5 MMscfd
Gas Maximum Pressure: 1000 psig
Gas Minimum Pressure: 500 psig
Gas Temperature: 100 deg F
One of Our Process Engineer have sized inlet and outlet piping on Contactor based on Maximum flow rate (30 MMscfd) and Minimum Pressure of 500 psig. Which comes out to be 8”. The gas velocity in 8” @1000 psig with 30 MMscfd is around 15 ft/sec. when gas flow rate and pressure reduces, the velocity with also decrease. My question is basically " Is there in impact on process if velocity is 15 ft/sec or less".
Thank you very much in advance
