I was wondering is anyone knows how to calculate the dynamic fluid viscosity for a slurry thats consists of 75% (NH4)SO4 and 25% Nickel by volume. We know thats its density is 3160kg/m^3.
Dynamic Fluid Viscosity
Started by Guest_Shan_*, Apr 03 2006 10:56 AM
Guest_Shan_*
Posted 03 April 2006 - 10:56 AM
Posted 04 April 2006 - 07:34 AM
Where is the liquid? You describe a mixture of two solids, ans write of a slurry.
If what you have is a mixture os ammonium sulfate solution at a given viscosity Mul, then an estimate of the solids-liquid mix is given by Kunitz
Mu(mix)=Mu(liquid)*(1+0.5 Vsol)/((1-Vsol)^4) where Vsol is the solids volume fraction.
Be careful on two points: The above correlation works best for low Vsol (<10%, you have 25%); also, the suspension is likely to be highly non newtonian, so there is no single value for a "viscosity"
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
