Hi to all!
Colleagues! I have problem with calculation of critical gas velocity to avoid liquid accumulation in wet gas pipelines. We had to purge some of our wet gas pipelines for 5 times in a week due to liquid (water, condensate) blockage in low places of pipeline vertical profile. Can you help me with determination of gas velocity we need to sweep out liquid and have stable flow without such problems?
As I know from my calculations our pipelines have stratified flow regime (it also confirmed by GAP calculations).
Data:
Gas rate = 1116000 Nm3/day
Z-factor = 0.68
Gas rate at linear conditions = 9000 m3/day
Liquid rate = 263 tonnes/day
Liquid density = 0.762 tonnes/m3
Average pipeline pressure = 8.9 MPa
Average pipeline temperature = 22 C (It varies from 33 (at the beggining of pipeline) to 11 C (at the end))
Inner diameter = 179 mm
Can you help me with it?
Best regards,
Konyashkin Nikita,
Junior Process Engineer
Oil, Gas and Condensate Production Department
CJSC ROSPAN International
