Hi all,
Can anybody explain me about entropy changes during expansion and compression processes.
I would appreciate --- A detailed mechanism of entropy changes , including correlations, if possible.
example: liquefaction of natural gas, which includes expansion and compression processes.
thanks a lot
mark.
Entropy
Started by Guest_mark_*, Apr 06 2006 09:35 PM
Guest_mark_*
Posted 06 April 2006 - 09:35 PM
Posted 24 June 2006 - 02:55 PM
Mark:
For an isentropic compression and expansion, the entropy change is equal to zero.
For a perfect gas that follows the ideal gas state equation, the temperature and pressure relationship is as follows:
T2/T1 = (p2/p1)^(k-1)/k
Thanks,
Gordan
Thanks,
Gordan
Posted 24 June 2006 - 05:48 PM
Mark:
Before I can discuss and preach on Thermodynamics, I (& I believe, the rest of the Forum) need to know what is your academic (& work) experience with Thermodynamics. What level of Chemical (or other) Engineering do you find yourself in at present? Have you sucessfully concluded such Thermodynamic-related courses such as:
Physics, Physical Chemistry, Chemical Engineering Thermodynamics, Mechanical Engineering Thermodynamics, etc. etc.,?
It will be extremely difficult to discuss Thermodynamic properties and much less Thermodynamic cycles and processes unless you have already had a firm and thorough exposure to Thermo courses. Otherwise, this thread will fail miserably in trying to identify your needs and help you out. You are inquiring about Entropy and about Isentropic processes. You should already have a mastery of the Mollier or T-S Diagram and be able to follow the cycle path on the Diagram.
Can you please furnish the above information in order to be able to tailor our response to your level of preparation? I'm sure a lot of good engineers on this Forum are willing to help you out if they can figure out what you need to know and what you can understand with respect to Thermodynamics.
I'll await your response.
Posted 25 June 2006 - 11:04 AM
Art:
Thanks for your post and additional questions that you asked in order to provide a complete answer to the question.
It is good to have you and help us, Forum members, deliver good feedback to asked questions.
I have to admit that when trying to provide answers, I do try to make it maybe too much straight forward.
Thanks,
Gordan
Thanks,
Gordan
Compressor Calcs - Polytropic Work & EntropyStarted by Guest_SickPuppy0_* , 28 Dec 2022 |
Enthalpy Of The Exit Stream Corresponding To The Inlet EntropyStarted by Guest_rahza.izak_* , 22 Sep 2022 |
Looking For Enthalpy (H) – Entropy (S) Chart For Chloromethane (MethylStarted by Guest_fredlan54_* , 18 Jul 2022 |
Water Entropy EstimationStarted by Guest_ahmedi_* , 19 Dec 2021 |
![]() Hysys Reference For Entropy? Why Hysys Entropy Numbers Are Different FStarted by Guest_stratovona266_* , 31 May 2017 |
