Dear All,
I had a query related to Hydro test Pressure.
For Example,
Suppose my Pump Discharge pipeline has,
Operating Pressure = 5 barg,Operating Temperature = 40 Deg C
Max. Operating Pressure = 6 barg.
Shut-off Pressure say = 8.5 barg,
I considered Shut-Off Pressure as my Design Pressure or more then that say 9 barg.
So my Design Pressure is 9 barg.
Hydrotest Pressure is 1.5 times Design Pressure,i.e, 13.5 barg.
Based on this i found that rating selected by me of 150 # is ok.
Hydrotest is carried out i found that there is no leaking at any point.
But, what if case when i carry out a surge analysis of pipeline with MOV at outlet.
I found that surge pressure is more than hydrotest pressure.
which means there may be leakage or bursting of pipeline or any point of surge line.
So is that i shall limit the surge pressure in pipeline below hydrotest pressure or the hydrotest pressure shall be carried out on mechanical design pressure condition of 150 # as per ASME.B31.3 Process Piping
What shall i do in that case.Pls guide.
Nagarajan K
