mohamad,
This is a very basic engineering application that has been discussed numerous times in our Forums. For some reason, the principles of condensate formation and vapor-liquid separation are not well understood by some members. Allow me to reinforce what Fallah has so kindly furnished as experienced, correct recommendations:
Please refer to the attached Excel workbook for a detail of what I see as mistaken balance line applications in your two installations. It is obvious to me that both of your existing installations have been done wrong in a “trial and error” method and not with an accurate and correct engineering understanding of what is going on.
A balance or equalization line is a small diameter pipe that tries to equalize the pressures existing on the top of two vessels to allow for free, unrestricted draining of liquid from one vessel to another. In other words, it is an engineering application of using GRAVITY to one’s advantage. Without this equalization of pressure, it is difficult to ensure that the required draining will be done efficiently. The principle is as simple as that, and it should be applied it in the simplest manner possible.
You are wrong in stating “with just one line connecting top of the pot to below the pass partition plate we cannot balance pressure between inlet/outlet of steam side”. That is simply not true. There is no flow established in the vapor balance line; the steam in it is STATIC – it can’t flow because there is no displacement. By forcing the formed condensate to flow through the tubes due to gravity, you are ensuring that there will be on-going displacement of fluid within the reboiler’s tube bundle. THAT IS WHAT IS SUPPOSED TO HAPPEN. Your correct balance line is the one I show in RED in the workbook.
You are also wrong is stating “i think a line between pot and steam inlet is enough what would balance pressure in the reboiler and let the condensed water to flow to the pot by gravity”. While you might obtain condensate flow into the condensate pot, it will also be against a slightly higher pressure (the steam pressure in the steam inlet is higher). Therefore, you are not ensuring that the condensate level in the pot will be an accurate one. Fallah is absolutely correct in what he is recommending to you. Common sense should tell us that is the reason the equalization line is called exactly that – EQUALIZATION.
If you expect to accumulate non-condensables in the tube bundle and condensate pot (and I seriously believe you will), then that is another problem that is solved rather easily. You require a separate non-condensable vent from the balance line or below the tube bundle’s pass partition plate with a vent valve that is opened from time-to-time, accordingly to allow for venting the undesired, accumulated non-condensables. This is done either manually or automatically. How often you have to do this depends on your system and how efficiently you operate your steam system.
Reboiler Condensate Balance Line.xlsx 37.35KB
506 downloads
