hi, we were having some flow issues through one of the Liquid feed driers of ISOMERIZATION Unit. when the drier vessel was opened we found out that the Mol sieve has changed its color from white to dark brown. My question is what might be the reason of this color change will it effect on the activity of the Mol Sieve.
Mol Sieve Colour Change
Posted 20 July 2014 - 05:39 AM
Posted 20 July 2014 - 05:57 AM
bugti,
Has the vendor of the Mol Sieve been asked to explain about the reason of such color change...?
Edited by fallah, 20 July 2014 - 05:57 AM.
Posted 20 July 2014 - 08:52 AM
Most likely cause is contaminants in the liquid feed to the driers accumulating on the molsieves..
If you kept some of the dark brown molsieves you could try to extract the dirt and analyse it to identify it.
If not you should have the liquid feed analysed thoroughly.
Posted 20 July 2014 - 02:02 PM
Are you using the Molecular Sieve after regeneration process ?
I think it should be used in as per regeneration cycle (8-hours heating up to 200F and then cooling, 8-hours usage).
Posted 20 July 2014 - 09:18 PM
Yes waqas we are using the drier after regeneration.
Someone has told me that it might be due to the corrosion from NHT, we are sending sieve to the lab for testing for FeS in the mol sieves.
Posted 20 July 2014 - 11:04 PM
I'm reading a Stephen King book. You would think he knows the difference between drier and dryer. But he doesn't. Just like most chemical engineers.
Posted 17 August 2014 - 12:35 AM
which MS changed? Hydrogen dryer or Hydrocarbon?
Each type of MS will change color under other impurities. Remember what you see in Dräger tubes, chemical reaction between specific component with molecular sieve inside the tube is the reason of color changing. also I never heard anything about corrosion under MS.
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Molecular Sieve Regeneration At High PressureStarted by Guest_Victor_process_Engineer_* , 07 Jan 2025 |
![]() Sieve Tray Rating In Aspen PlusStarted by Guest_Root_* , 24 Sep 2023 |
![]() ![]() How Does A Vsd Gas Centrifugal Compressor React To A Demand ChangeStarted by Guest_AlexNguyen_* , 08 Jun 2023 |
Double Pass Sieve TrayStarted by Guest_xSammie_* , 01 Jun 2023 |
