Extraction Of Copper From Copper Ore (Extraction Solid-Liquid)
extraction
#1 rectification24
rectification24
  • 10 posts
Posted 07 August 2014 - 02:08 PM
Hey,
can someone please help me? I have one problem that I have to solve, but unfortunately I don't know if my result is correct.
Could someone please look at my work and tell me if I did any mistake?
I would be very grateful for any help.
Filip
Description of my problem could be seen here and solution down under:
Roasted copper ore containing the copper as CuSO4 is to be extracted in a counter-current
stage extractor. Charge consists of 10 tons of inert solids, 2 tons of
copper sulfate (CuSO4), and 0.5 ton of water. The strong solution produced is to
consist of 90% H2O and 10% CuSO4 by weight. The recovery of CuSO4 is to be 98% of
that in the ore. Pure water is to be used as the fresh solvent. After each stage, 1 ton of
inert solids retains 2 tons of water plus the copper sulfate dissolved in that water.
Equilibrium is attained in each stage. How many stages are required?
2 t CuSO4....................100%                                                       1.96t....................10%
      x       ......................98%                                                             x........................90%
x=1.96 t CuSO4        x=17.64 t H2O
extract:   1.96 t CuSO4/17.64 t H2O = 1.12 t CuSO4/10 t H2O
raffinate:
0.04 t CuSO4/10 t inert solid
As base we define 10 t of inert solid (without H2O and CuSO4)
CuSO4 in: 2 t
CuSO4 out:
0.04 +(1.12 /(1.12 +10) *(S-20+0.5)) = 0.101*S - 1.924
CuSOin = CuSO4 out
2 = 0.101*S - 1.924
S = 38.85 t H2O  (amount of solvent)
y= ((20*1.12/(1.12+10)) + (1.12/(1.12+10)*(38.85-20+0.5)) - 2 ) / 38.85
ya = 0.0505
yb = 0
ya* = 1.12/(1.12+10) = 0.101
yb* = 0.04/20 = 0.002
Number of stages:
N=log(y- yb*/(ya-ya*)) / log(yb-ya/(yb*- ya*))
N=4.8=5
  • 6,771 posts
Posted 08 August 2014 - 03:21 AM
My calculation , different from yours !
Ya 0.1 Yb 0 Xa =Ya* 0.16 Xb=Yb* 0.001332     N 8.248054
Edited by breizh, 08 August 2014 - 03:24 AM.
#3 rectification24
rectification24
  • 10 posts
Posted 08 August 2014 - 12:38 PM
Could you please send me your calculations that I will be able to see what I did wrong?
Filip
#4 breizh
  • 6,771 posts
Posted 09 August 2014 - 08:28 AM   Best Answer
Consider my excel sheet ! Nothing granted.
#5 rectification24
rectification24
  • 10 posts
Posted 10 August 2014 - 08:39 AM
Thanks a lot.
Filip
