Dear,
If distillation point of diesel is more than 360 0C, what does this mean for engine of vehicle? (please see the attachment)
Posted 18 August 2014 - 02:21 PM
Dear,
Posted 19 August 2014 - 12:06 AM Best Answer
Dear,
I am just correcting your statement, distillation point referred here corresponds to ASTM D86 95% recovery to max 360 deg C.
There are effects of targeting this temperature lower or higher and are detailed in below links,
http://www.eptq.com/...dd-f470520cce7d
http://www.isca.in/r...RS-2012-165.pdf
http://jeteas.schola...esel Engine.pdf
http://www.scielo.or...yf/v2n1/v2n1a03
Hope it helps.
Edited by Padmakar, 19 August 2014 - 12:07 AM.
Posted 19 August 2014 - 05:23 AM
If you want to sell diesel it has to confirm to the applicable diesel specification. If that diesel spec states a maximum of 360 oC for 95% temperature but your diesel is 367 oC then you may not be able to sell it as diesel.
A higher 95% temperature will result in higher emission of soot in car exhaust.
Edited by PingPong, 19 August 2014 - 05:24 AM.
![]() Dew Point CalculationStarted by Guest_Aditya000333_* , 17 Sep 2025 |
Kerosene Flash Point TroubleshootingStarted by Guest_zuberattan_* , 25 Oct 2009 |
![]() Negative Pressure At High Point?Started by Guest_mychemicalromance0425_* , 17 Aug 2024 |
![]() Chemical Injection PointStarted by Guest_Lyne_* , 15 May 2024 |
