We have two refineries one with lube based and fuel based refineries, if i use lube based crudes in fuel based crude operating distillation column shall i get still the fuels or not
Petroleum Fractionation
Posted 19 August 2014 - 08:37 PM
Posted 20 August 2014 - 02:04 AM
The main difference in Lube (non-energy) and Fuel (energy) refinery is configuration of Vacuum Distillation Unit and crude being processed. The straight run fuels from Crude Distillation Units will be same in both configurations such as LPG, Gasoline, Heavy Naphtha, Gas Oil etc. The VDU process only 370 deg C + material and configuration is further based on number of lube cuts i.e. one VDU or 2 VDU in series.
Lube cuts from lube bearing crude differ in kinematic viscosity compared to VGO from VDU. I don't see any issue if one wants to process lube bearing crude in fuel grade refinery to achieve fuels.
Dew Point Margin In Strippers & Fractionation ColumnsStarted by Guest_Venkat @89_* , 05 Sep 2023 |
Flash Point Importance For Petroleum ProductsStarted by Guest_Venkat @89_* , 05 Jun 2023 |
![]() Petroleum Assays Not Supported In DynamicsStarted by Guest_titim_* , 24 Jul 2018 |
Importance Of Sensitive Tray Temperature Control In Fractionation ColuStarted by Guest_mb23_* , 12 Feb 2023 |
![]() Hysys Petroleum AssayStarted by Guest_nasim303_* , 17 Jan 2023 |
