Dear all,
API STD 521 sec. 4.3.4.4, regarding the check valve flow area to be considered for reverse flow scenario of PRV sizing, states "one may estimate the reverse flow through series check valves as the flow through a single orifice with a diameter equal to one-tenth of the largest check valve’s nominal flow diameter.", while DEP 80.45.10.11-Gen sec. 2.11.1 point 5 states "Where there are dual Class 1 check valves, calculate the backflow assuming a check valve flow area of 10 % for new facilities."
10% of area and 10% of diameter do give significantly different PRV orifice sizes.
Could someone enlighten me why the two standards differ and which one would be more appropriate.
