Vacuum System Loading?
vacuum system loading
#1 harshchem55
harshchem55
  • 12 posts
Posted 10 September 2014 - 10:27 AM
I have a general query regarding vacuum system loading. If the vaccum system (Ejector + booster system ) suction load is designed for say 100 kg/hr @ 3 mbar suction pressure and if any time this suction load is less than 100 kg/hr will there be any fluctuation in vaccum.
Please expalin me about how the vacuum system loading is acheived.
  • 6,732 posts
Posted 10 September 2014 - 10:43 AM
http://www.graham-mf...cuments-library
Probably good to read the documents attached !
For a better understanding can you upload a sketch of your system , somewhere you should have an automatic valve to control the pressure ?
To my knowledge you encounter troubles when the motive stream is not stable or because of quality change .
hope this helps.
