Weight Of Shell & Tube Heat Exchanger
#1 tyagzz004
tyagzz004
  • 3 posts
Posted 23 September 2014 - 04:48 AM
I am calculatiing the weight if Shell & tube heat Exchanger...
Type                 Vertical
MOC                 SS304
HTA                30 meter Sq.
Type               Shell & tube
No. of Tubes   125
Tube length      3000mm
Tube O.D.        25.4 mm
PAsses               4
BAffles               5
Hanging support   4
Shell Thickness   4 mm
Tube thickness    1.6mm
Header                 4mm
Tube Plate            20mm
Baffles                  3mm
M.S. Back Flange  65*20mm
Nozzle Dia with MS Flange
Vapor Outlet        480mm
Liquid Inlet            300mm
STeam Inlet          250 mm
COndensate         100mm
I have calculated the Shell Weight, Tube Weight, Tube Sheet Weight,Weight of Baffles.
Please tell me the steps for calculation of Nozzle Weight, Head Weight, Flanges Weight??????
SO I can complete my calculation.,
Posted 23 September 2014 - 08:28 AM
I am sorry to say that this is a ridiculously easy problem to solve today – by simply using the Google search engine on the internet.  I have my own weight spreadsheets that I compiled many years ago in order to resolve weight problems and I would assume that you should do the same.
Do you have any problems with keying in “flange weight”, “pipe weight”, “pipe cap weight” on the Google search engine?  That’s where you will find hundreds of sites giving you all this information.
