What is Blow down valve (BDV) and its purpose? When should a BDV be used for a process vessel?
Posted 24 September 2014 - 01:42 PM
Posted 24 September 2014 - 02:30 PM
API 521 is good getting started to understand the blowdown valve and its function...
But, in brief, it's an on/off valve to be opened manually or automatically in order to depressuring a pressurized vessel on which the valve has already been installed...
As per API 521 it should be considered for the large vessels with the operating pressure higher than 1700 kPag and are subject to a pool fire...
Posted 27 September 2014 - 11:05 AM
Thank you. I am going through API 521 now.
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
