Hi
Thanks for sharing the information.
That's a tough one! I am just guessing here... lets see what experts have to say!
I guess 24 deg C after H-1160 A is your requirement for TEG Unit. Now the extra condensate formed in V-1159A due to further lowering of temperature needs to be recovered by directly routing to V-0151 or by routing to V-1157 A (same as in current process)
Condensate formed is around 11000 kg/h. If we flash it to 22.8 pressure, vapor fraction shall be 0.3 (30 % vapor) but if we flash to 10.1, vapor fraction shall be 0.4 (40% vapor)
Now, routing back to V-0151 will not make sense because if vapor load is recycled back, it will lead to more compressor load and loss of heavier hydrocarbons. However, routing it back to V-1157 A will also increase load but to some lower extent.
However, one benefit I could envisage by going through this scheme is that it will actually maximize condensate recovery and it shall lower down the temperature of 2nd stage suction temperature which may ultimately lead to lower power consumption.
It's just guessing and I am eagerly waiting for the experts comments...
Himant
