Cstr Unknown Dimensionless Heat Transfer Coefficient
process; cstr;
#1 wobbler28
wobbler28
Posted 01 October 2014 - 01:50 AM
I'm trying to reproduce in Matlab the model of a continuous stirred tank reactor (CSTR) that I've gotten for a project.
The model is written in the state space and uses some dimensionless values, including a "heat transfer coefficient" β. Here's the table:
I've been trying to investigate in chemical process books to figure out how to calculate this coefficient (I imagine the numerator is Area times Height, but no idea about the terms in the denominator), but I've found nothing. I think even the order of magnitude of this coefficient would be useful, so I don't mess up when entering the equations. Thanks in advance for your help.
  • 6,769 posts
Posted 01 October 2014 - 02:13 AM
I don't believe so , h should be the heat transfer coefficient , refer to the definition of the Nusselt and Correlation for heat transfer in CSTR .
The document attached will confirm it:
http://www-bisc.cs.b...ersNik/DNNC.pdf
Note : Knowing that Beta is dimensionless and knowing the dimension of the other terms , you should be able to check the dimension of h !
Hope this helps
Edited by breizh, 01 October 2014 - 06:26 AM.
#3 PingPong
PingPong
  • 1,469 posts
Posted 01 October 2014 - 04:19 AM
h = heat transfer coefficient
A = heat transfer area
Fo = volumetric flowrate of heat transfer medium in jacket
ρ = density of heat transfer medium
cp = specific heat capacity of heat transfer medium
#4 wobbler28
wobbler28
Posted 01 October 2014 - 10:45 AM
Thanks very much for your answers, I think I'm now able to get the right value.
Best regards.
