Messers
I am to work on a separation process for extracting MEG, DEG and TEG from spent / crude glycols after removing the water present. The column can be a batch / continuous one as of now, because
I understand from a preliminary literature survey that this operation is carried out usually in differenct ways:
(a) 5-6 columns each separating MEG / DEG / TEG / PEG etc.
(b ) 2 batch columns, operating under vacuum, water being separated in the first and MEG, DEG and TEG removed as top cuts in successive operations in the second column.
I have started simulating this system in Chemcad based on an assumed feed composition.
However, I feel I need to further read up on the process and understand how to optimally carry out this design for this system. Can someone please direct to some literature / journals / publications dealing with similar process so that I can decide if the column will be a batch / continuous / tray / packed etc.
