what is the difference between degas pipe and two phase separater? I need your help.THX
What Is Degas Pipe, Could Anyone Help Me ?
Posted 19 October 2014 - 02:55 AM
Posted 19 October 2014 - 05:07 AM
What you call a degas line is probably what I call a vent line to allow the release of gas ,installed on equipment or on pipe .A 2 phase separator is a mechanical equipment designed for the separation between liquid and gas . Try the search engine or Google ,key words " Gas liquid separator ".
Hope this helps
Posted 27 October 2014 - 04:31 AM
I have used degassing pipe upstream of storage tank. Basically it is used to remove gases in the feed stream. Usually, It is fabricated from the piping piece, hence does not call for ASME code. However, two phase seperator is equipment and designed as per ASME code and used for liquid/gas separation. When we talk about two phase separator, efficiency of the seperation also comes in the picture. What I mean is for degasser it is envisaged to have bulk separation only and do not have any internals usually. While in two phase seperator you will be having distributor, mist eliminator or cyclone or vane plate etc as per the process call and efficiency required for seperation.
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
![]() Pipe Entrance And Exit LossesStarted by Guest_katmar_* , 13 Nov 2024 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
