Define A Set Of Default Units In Prode
units prode excel
#1 neriet
neriet
  • 16 posts
Posted 21 October 2014 - 02:35 AM
I know that Prode Properties allows to change units by code
or with Dialog Editor and that I can save all units and settings in files,
(menu Save a Archive in Excel)
it may seem a stupid question but how can I change the default units and settings ?
I wish to set all units to US as default
#2 marchem
marchem
  • 153 posts
Posted 21 October 2014 - 05:38 AM
you can simply save the desired values on ppp.def ,
the file which Prode Properties utilizes to store all defaul values
1) define your preferred units, settings etc.
2) save (menu Save a Archive in Excel) with the name def.ppp
then Properties will load your preferred units
#3 neriet
neriet
  • 16 posts
Posted 21 October 2014 - 11:48 AM
so, it's the def.ppp file,
I had forgotten that,
thanks marchem,
I presume it works as other files,
storing all data including all stream's compositions.
#4 serra
serra
  • 311 posts
Posted 23 October 2014 - 12:36 AM
yes, you can store preferred units, settings, compositions in def.ppp,
another possibility is to use a script,
see
"http://www.harveyhen...in-mathcad-ppp"
Edited by serra, 23 October 2014 - 12:38 AM.
