Proii Column Simulation
#1 gunji
gunji
  • 16 posts
Posted 25 October 2014 - 10:16 AM
Hi everyone
I'm now using the version 9.0 of ProII and i am simulting a process including a column. Unfortunately, in print options, the Vloads parameters is not available, parameters that i need to calculate the column diameter. Can you tell me where to have it in this new version of PROII.
thanks a lot
#2 PingPong
PingPong
  • 1,472 posts
Posted 25 October 2014 - 01:23 PM
It is very easy to calculate Vload by hand. Helps you to understand what you are doing.
If you let PRO/II or Provision perform a column sizing or column rating, the output will list the VLOAD for all trays.
#3 gunji
gunji
  • 16 posts
Posted 29 October 2014 - 12:01 PM
thanks i solved the problems!!
