Shell And Helical Coil Condenser
design
#1 Chigana
Chigana
Posted 24 November 2014 - 05:41 AM
I am trying to design a shell and coil condenser, I have the process fluid on the shell side with cooling water in the tube.
Please can I get guidance on how to go about the design. I don't have the cooling water flow rate and cooling water outlet temperature.
Thanks.
Posted 24 November 2014 - 01:27 PM
My best advice on this subject is to first read, study, and then apply the information found in Donald Q. Kern's book, "Process Heat Transfer", McGraw-Hill; 1950, Chapter 20 - "Additional Applications"; page 720, Section 2. "Coils".
Kern discusses the methodology of designing a coil-type of heat exchanger - either helical or "pancake" type.
#3 breizh
  • 6,801 posts
Posted 25 November 2014 - 09:56 PM
chigana ,
If you cannot get access to reference given by Art , consider the document attached to support your work .
Good Luck
Edited by breizh, 25 November 2014 - 10:01 PM.
#4 Chigana
Chigana
Posted 26 November 2014 - 10:34 AM
Thanks a lot, Art and Breizh, You've been so helpful.
Chigana
